I check for power with a test light on the back of the gages and one terminal on each gage makes the test light flicker . I cant get it to keep a constant light , like I got a bad connection but no matter how I wiggle the connections it still just flashes intermittenly . The steering colum and dash panal are loose . Do they need to be tight to get a good ground ? Thanks . BooBoo . I,m wrong , I,m getting a flickering light on both terminals on both gages .
Worn Fuel Pump Pushrod | 67RTBlue | 3 | 18,365 |
09-05-18, 09:09 AM Last Post: 67RTBlue |
Brake light gremilins | Hibbing_Coronet_500 | 3 | 4,129 |
03-14-17, 06:16 PM Last Post: ws27 |
Fuel tank vents | Stargazer | 11 | 8,084 |
08-04-16, 10:28 PM Last Post: metaldad |
Brake warning light stays on | 67RTBlue | 7 | 5,610 |
06-10-16, 08:55 PM Last Post: 67RTBlue |
Tail Light Bulb Holder | NZ 68 R/T | 19 | 9,554 |
02-04-16, 11:54 AM Last Post: Racer Brown |
Fuel tank to fuel line rubber hose picture | 67RTBlue | 12 | 6,972 |
01-27-16, 02:25 PM Last Post: Racer Brown |
Fuel filler leaking | cnmsales | 5 | 4,006 |
12-18-15, 06:01 PM Last Post: thebankerstoy |
Has anyone Added an in tank fuel pump For carby setup instead of standard electric | Jpr777 | 5 | 3,272 |
10-08-15, 06:56 PM Last Post: Drag-Net |
Fuel gauge has me stumped. | Billb66 | 11 | 7,351 |
08-28-15, 10:19 PM Last Post: Billb66 |
Fuel pressure of a stock 318 | tkarman | 2 | 3,148 |
05-22-15, 03:26 PM Last Post: tkarman |
Users browsing this thread: |
1 Guest(s) |
