Tail Light Bulb Holder
Merry Xmas and a Happy NY to all.
Can anyone post a pic of the correct bulb holder for a 68 Coronet R/T.7639]
I have 2 different styles, and this longer one makes the light on one side glow brighter as it's closer to the lense. The one on the other side is much shorter. Which one is correct?
Thanks
I'm no expert on the newer cars but I'd be a little worried the longer one might melt the lens.
Lots of times, the uneven lighting is because of the reflector not being the same on each side. If you haven't done it already, I'd suggest to at least check out the reflectors. An easy fix if you need is to clean them and paint them with chrome paint. Then they will at least be even.
Same as Rich said, I'm not an expert on the later cars either, but below is what the 1968 Factory Parts Book says your 68 Coronet should be using for these sockets. If you're lucky, there will be a Chrysler part number stamped on both the short and long sockets and one of those part numbers will hopefully match the one below.
Factory Parts Book section: 8-55-57 (electrical section)
Part number: 2631 432
Description: socket, tail, stop and turn signal lamp
Number used per car: 2
Application: L (Dart)
Application: R (Belvedere)
Application: W (Coronet) except Charger, except station wagon
I hope this helps and Happy New Year to you as well!
P.S. I'd also agree with Rich that the shorter socket would give more room between the original style heat producing bulbs and the plastic tail lamp lens which is always helpful in trying to avoid heat checking the fragile tail lamp lenses. Wink
Hi, thanks for the answers. I'll check out what part numbers I have and the state of the reflectors as soon as I can.
Can anyone recommend a high brightness, low heat bulb replacement?
LED bulbs?
Just one LED tail lamp bulb option for your 1968 Coronet from a large company called Carid.
Website page link for these LED bulbs:
http://www.carid.com/1968-dodge-coronet-...11410.html
Quote:Dodge Coronet 1968, Tail Light LED Bulbs by Lumen®. Each bulb sold separately. Increase the light output, safety and style of your tail lights with light emitting diode bulbs from Lumen. LEDs match the size and shape of your vehicle's original equipment and install easily without modification. Sealed, moisture-proof casings are extremely resistant to vibration, and because substrate in the bulb does not get consumed during use, it will typically last a lifetime once installed on your vehicle. Available in multiple colors. 1-year manufacturer warranty. Replaces the following bulb types: 94 / 1016 / 1076 / 1142 / 1196 / 2057 / 2357 / 2397 / 3496 / 7225 / 7528. Available in Amber, Red and White.
And an Ebay auction for LED bulbs that are a direct replacement for the factory 1157 tail lamp bulbs.
Ebay auction link: http://www.ebay.com/itm/White-LED-1157-1...cl&vxp=mtr
[Image: s-l1600.jpg]
I picked up a set of led lites for my R/T at Walmart that work really well. I think they were about $15.00.
Hi, I can't find a part number on either bulb holder. can anyone post a pic or dimensions of the correct one, and possibly a source?
Anyone with a 68 have the answer?
  70 dodge head light grills 70rtvert 1 2,820 03-23-15, 08:52 PM
Last Post: ramtough
  Instrument Bulb Socket? shuba 2 3,731 12-02-14, 02:11 AM
Last Post: shuba
  External Gauge light Avenger 5 4,627 09-05-13, 07:51 AM
  Back up light switch location jeffmc 1 3,160 07-13-13, 12:08 AM
  Tail light issues. Avenger 2 3,601 05-28-13, 06:32 PM
  Light and wiper switch removal 67 Coronet JohnS 3 3,526 04-23-13, 10:14 PM
Last Post: Copper67440
  fuel gage and temp light inop on 67 BooBoo 18 9,622 04-22-13, 12:16 PM
Last Post: BooBoo
