Brake light gremilins
Just a quick FYI.
When I bought my 67 I noticed my break lights stayed on after exiting the car. If I remembered? I would pull up on the pedal with my foot to make the lights go out. A few dead batteries later and I solved the problem. The switch was not out of adjustment. The wire connector to the switch had caused the switch to rotate downward and the connector itself was keeping the switch held open. I rotated the switch and its connector 180 degrees and the switch closes and no more dead batteries.
Thanks for posting
I've had that same problem
I'll have to remember that the next time I have a problem. The last time was Jim's wagon. I don't remember exactly what I did to fix it.
Thanks
Last Post: herklots
  Tail Light Bulb Holder NZ 68 R/T 19 9,554 02-04-16, 11:54 AM
