04-12-17, 06:41 PM
		Got my new front drums from classic industries. ( Made in China )
They have a great finish on them and the machine work is nice.
Except they are obviously out of balance. As you spin the drum you can see ovality in the casting that causes the drum to stop in the same spot every time you spin the drum.
I measured the "cast iron ovality run out" to a exact spot on the drum with a dial indicator at .050.
That spot always spins back to 6 oclock position.
Would I look like a fool if I asked a tire shop if they could balance my drums?
If not?
Ill use sticky square wheel weights at 180 from the heavy spot until the prepencity to turn back to the 6 oclock has ended.
Forgive my misspellings ( Big words today )
Thoughts on this
Thanks
If not?
Thoughts on this
Thanks
