55-56 horn button center piece restoration
Anyone had a horn button center piece rechromed? If so, did you take the gold medallion off? It looks like you have to drill out a rivet on the back side. I have never seen a replacement medallion for the horn button, so I wanted to know how someone else did this?
Thanks.
Sutton
Picture? If it is what I think it is, I grind off the rivet and then carefully drill and tap the chrome piece for small screws in my Bridgeport milling machine.
Where are you located?
[URL="https://www.ebay.com/itm/1955-1956-Dodge-Steering-Wheel-Horn-Button-1614645-Good-Driver-Quality/372104634376?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649"]https://www.ebay.com/itm/1955-1956-Dodge-Steering-Wheel-Horn-Button-1614645-Good-Driver-Quality/372104634376?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
[/URL]
Here's one from eBay. On the back side center there is a rivet that must be drilled out for the medallion to come loose. I want to rechrome, repaint, and then put medallion back. Didn't know if anyone had done that before.
I'm near Atlanta, GA.
Well that is different than what I expected. Never took one apart that looked like that.
How will you reattach it when you drill out the rivet?
Don't know. I was hoping someone had done this before and knew how to do it.
  Horn button on 67 with wood wheel 67RTBlue 9 2,433 02-15-23, 04:36 PM
  Last piece of the puzzle - 1966 Coronet convertible window trim CoVert66 3 1,048 09-23-22, 03:58 PM
  1955 Dodge/Plymouth door handle button removal dodge55 2 24,219 02-18-18, 11:42 PM
Last Post: dodge55
  antique radio restoration shops dodge55 3 14,360 02-11-18, 06:06 PM
Last Post: dodge55
  1967 Horn Relay Connector Housing TX67RT 1 19,032 10-06-17, 06:31 PM
  '67 Center grille bolts-correct style? 67RTBlue 0 3,732 06-29-16, 12:52 PM
  Some Rear Driveline Restoration... TX67RT 15 9,955 10-30-15, 01:06 PM
Last Post: Warhawkfight34
  How do I remove this piece of trim? Kj3800 3 4,234 04-11-15, 09:37 PM
Last Post: Kj3800
  RedLine Dog Dish Restoration Billb66 20 12,549 02-28-15, 02:56 PM
  Almost finished the dash restoration Warhawkfight34 8 5,802 12-21-13, 08:57 AM
Last Post: MightyMopar69
