1967 Horn Relay Connector Housing
I posted this up in the "wanted" section, but thought I may as well post it here too. Doing some clean-up in the engine compartment of my '67 R/T, and noticed that my horn relay connector must have gotten warm at some point; it's melted a little bit. I'd like to replace it while I'm doing the work, and haven't found anyone out there selling new ones. Can buy the entire harness, but not just the horn relay housing. Does anyone know a source for these that I might not be aware of? In lieu of that, does anyone have a parts harness they'd be willing to part with, or sell me the (good) horn relay connector housing? My wiring and terminals are good; just the plastic housing is bad.
Thanks!
JD
You can check out any time you like, but you can never leave...
I have an old harness at home, I'll check to see if it has the connector on it for you.
  Horn button on 67 with wood wheel 67RTBlue 9 2,433 02-15-23, 04:36 PM
  1967 Coronet needs hood alignment 440net 1 1,485 10-15-21, 07:38 AM
  55-56 horn button center piece restoration dodge55 4 22,716 02-11-18, 06:05 PM
Last Post: dodge55
  1966 & 1967 Dodge & Plymouth B-Body Front Windshield Trim thebankerstoy 0 3,720 12-30-14, 12:20 AM
  Where to find door skins for 1967? mykenytemare 7 5,978 11-23-14, 06:17 PM
Last Post: shuba
