1966 & 1967 Dodge & Plymouth B-Body Front Windshield Trim
Here is a complete parts interchange guide for all of the 1966 and 1967 Dodge Coronet, Dodge Charger and Plymouth Belvedere B-Body models outside front windshield moulding trim. It basically breaks down to the following three body style groups.
Group 1: all 1966 and 1967 2 door hardtop models
Group 2: all 1966 and 1967 convertible coupe models
Group 3: all 1966 and 1967 2 door sedans, all 1966 and 1967 4 door sedans, all 1966 and 1967 station wagon models
Some of this windshield moulding trim is NOT interchangeable between the above three groups of body styles, so please check the part numbers carefully!
Information that I will post for each part includes the following:
(01) Section number. This is the section number in both the 1966 and 1967 Factory Parts Book where the listed part can be found.
(02) Part number. If there is a left and right side for any given part I will notate this.
(03) Part description. I will list the parts as they are found in the 1966 and 1967 Factory Parts Books except that I will use full words rather than abbreviations as Chrysler did in the parts books to save space.
(04) Number used. This will show how many of each part is used per vehicle.
(05) Application. I will post each model that uses the listed part so folks will know exactly which parts fit their particular car. This will also help owners understand which other Dodge and Plymouth models can be sourced for these parts.
1966 and 1967 Front Windshield Moulding Trim - UPPER (TOP) SECTION:
Section number: 23-23-65 (you will then be referred to the Exterior Moulding Illustrations and Moulding Legends in the front of Group 23 Body Section for each model)
Part number: 2664 809
Part description: moulding package, windshield, outside, upper
Number used: 1
Application: 1966 Coronet 440 (W-H) 2 door hardtop
Application: 1966 Coronet 500 (W-P) 2 door hardtop (1966 Factory Parts Book lists part number 2584 699, this is INCORRECT! CORRECT part # is 2664 809!)
Application: 1966 Charger (W-P) all
Application: 1966 Plymouth Belvedere I (R-H) 2 door hardtop
Application: 1966 Plymouth Satellite (R-P) 2 door hardtop
Application: 1967 Coronet 440 (W-H) 2 door hardtop
Application: 1967 Coronet 500 (W-P) 2 door hardtop
Application: 1967 Coronet R/T (W-P) 2 door hardtop
Application: 1967 Charger (W-P) all
Application: 1967 Plymouth Belvedere II (R-H) 2 door hardtop
Application: 1967 Plymouth Satellite (R-P) 2 door hardtop
Application: 1967 Plymouth GTX (R-P) 2 door hardtop
Part number: 2586 272 (passenger side)
Part number: 2586 273 (drivers side)
Number used: 1 of each part number
Application: 1966 Coronet 440 (W-H) convertible coupe
Application: 1966 Coronet 500 (W-P) convertible coupe
Application: 1966 Plymouth Belvedere II (R-H) convertible coupe
Application: 1966 Plymouth Satellite (R-P) convertible coupe
Application: 1967 Coronet 440 (W-H) convertible coupe
Application: 1967 Coronet 500 (W-P) convertible coupe
Application: 1967 Coronet R/T (W-P) convertible coupe
Application: 1967 Plymouth Belvedere II (R-H) convertible coupe
Application: 1967 Plymouth Satellite (R-P) convertible coupe
Application: 1967 Plymouth GTX (R-P) convertible coupe
Part number: 2584 699
Number used: 1
Application: 1966 Coronet Deluxe (W-L) 2 door sedan
Application: 1966 Coronet Deluxe (W-L) 4 door sedan
Application: 1966 Coronet Deluxe (W-L) station wagon
Application: 1966 Coronet 440 (W-H) 4 door sedan
Application: 1966 Coronet 440 (W-H) station wagon
Application: 1966 Coronet 500 (W-P) 4 door sedan
Application: 1966 Plymouth Belvedere I (R-L) 2 door sedan
Application: 1966 Plymouth Belvedere I (R-L) 4 door sedan
Application: 1966 Plymouth Belvedere I (R-L) station wagon
Application: 1966 Plymouth Belvedere II (R-H) 4 door sedan
Application: 1966 Plymouth Belvedere II (R-H) station wagon
Application: 1967 Coronet (W-E) station wagon
Application: 1967 Coronet (W-E) 2 door sedan
Application: 1967 Coronet Deluxe (W-L) 4 door sedan
Application: 1967 Coronet Deluxe (W-L) station wagon
Application: 1967 Coronet 440 (W-H) 4 door sedan
Application: 1967 Coronet 440 (W-H) station wagon
Application: 1967 Coronet 500 (W-P) 4 door sedan
Application: 1967 Plymouth Belvedere (R-E) station wagon
Application: 1967 Plymouth Belvedere I (R-L) 2 door sedan
Application: 1967 Plymouth Belvedere I (R-L) 4 door sedan
Application: 1967 Plymouth Belvedere I (R-L) station wagon
Application: 1967 Plymouth Belvedere II (R-H) 4 door sedan
Application: 1967 Plymouth Belvedere II (R-H) station wagon
1966 and 1967 Front Windshield Moulding Trim - LOWER (BOTTOM) SECTION:
Part number: 2585 852 (passenger side)
Part number: 2585 853 (drivers side)
Part description: moulding package, windshield, outside, finish, lower
Application: 1966 Plymouth Belvedere II (R-H) 2 door hardtop
Application: 1967 Coronet Deluxe (W-L) 2 door sedan
Application: 1967 Plymouth Belvedere I (R-L) station wagon (1967 Factory Parts Book lists part numbers 2585 952 and 2585 953, this is INCORRECT! CORRECT part numbers are 2585 852 and 2585 853!)
Application: 1967 Plymouth Satellite (R-P) convertible coupe (1967 Factory Parts Book lists part numbers 2585 952 and 2585 953, this is INCORRECT! CORRECT part numbers are 2585 852 and 2585 853!)
1966 And 1967 Front Windshield Moulding Trim - SIDE SECTIONS:
Part number: 2585 854 (passenger side)
Part number: 2585 855 (drivers side)
Part description: moulding package, windshield, outside, finish, side
Part number: 2586 274 (passenger side)
Part number: 2586 275 (drivers side)
Part number: 2585 850 (passenger side)
Part number: 2585 851 (drivers side)
  Last piece of the puzzle - 1966 Coronet convertible window trim CoVert66 3 1,046 09-23-22, 03:58 PM
  1967 Coronet needs hood alignment 440net 1 1,484 10-15-21, 07:38 AM
  1955/56 Dodge trunk torsion bar installation dodge55 1 17,678 01-25-20, 03:25 PM
  convertible rear seat trim bike_guy123 3 25,606 06-30-18, 07:17 PM
Last Post: bike_guy123
  1955 Dodge/Plymouth door handle button removal dodge55 2 24,219 02-18-18, 11:42 PM
Last Post: dodge55
  1967 Horn Relay Connector Housing TX67RT 1 19,032 10-06-17, 06:31 PM
  1966 Coronet 500 rear leaf springs richardmay2 3 13,427 07-18-17, 01:30 PM
  1966 B-Body theman440 9 14,639 07-11-17, 06:12 AM
Last Post: jtoby25
