1955 Dodge/Plymouth door handle button removal
Anyone ever taken out the door handle button from the door handle before? It looks like the the back round housing is wedged into place holding the button into place and there is a slot to use a screwdriver to pry it out. But, I don't want to break anything. I want to rechrome all 4 of my handles, but I have to get the buttons out first.
Sutton
Pictures? I know I had the handles off my 50 Plymouth but that was a long time ago............
I figured it out. There is a tab you can't see in which you have to stick an awl or toothpick down in the slot. Press in and the backing comes out. You might have to slightly pry the backing up due to grit, but once the tab is pressed in, it should come right out.
  Horn button on 67 with wood wheel 67RTBlue 9 2,431 02-15-23, 04:36 PM
  1955/56 Dodge trunk torsion bar installation dodge55 1 17,678 01-25-20, 03:25 PM
  55-56 horn button center piece restoration dodge55 4 22,716 02-11-18, 06:05 PM
Last Post: dodge55
  1965 Dodge Coronet 440 Front bumper brackets Moe832 4 5,220 06-23-15, 04:49 PM
  1970 Coronet Door Striker Screws Wanted blownNinjected 4 4,175 02-27-15, 11:02 PM
Last Post: blownNinjected
  Best weatherstripping company? Door and window seals 67RTBlue 1 3,446 01-29-15, 01:05 PM
Last Post: Warhawkfight34
  Door hinges theman440 11 9,137 01-28-15, 12:22 AM
  1966 & 1967 Dodge & Plymouth B-Body Front Windshield Trim thebankerstoy 0 3,719 12-30-14, 12:20 AM
  Where to find door skins for 1967? mykenytemare 7 5,978 11-23-14, 06:17 PM
Last Post: shuba
