convertible rear seat trim
Looking for a little help / guidance with the installation of the 2 trim panels that go behind the top of the rear seat in a 66 / 67 convertible. I can't remember how they came out. If anyone has any pics of this or can explain how they mount in. One that has the stainless trim mounted to it that the boot slides into.... that one is pretty easy, the one I don't know for sure is the panel that has the slotted key hole mounts in it........where does it belong?
11472
Here is a pic of it....I went and looked at a 67 convertible as a reference......I could not find this anywhere.....I am starting to wonder if its even for the car? I can't find any bolt hole patterns in the car that match up either.
11471
Mike, I dont believe that part belongs to the car. The panel behind the seat that holds the rail for the boot is just 1 piece.
Thank you... I believe that is correct. When I brought all the pieces from the shed to the garage, the panel that mounts behind the seat was next to this piece...same color, same steel. Heck, that piece even has glue on it that looked similar to glue/caulk used across the header under the stainless. I assumed they went together. As you know, I've parted a few cars over the years and if that thing even goes in a car, it's probably for a Charger of the same era. Thanks again for the response.
  Rear-end Re-fresh theman440 43 252 10-16-25, 07:27 PM
  Last piece of the puzzle - 1966 Coronet convertible window trim CoVert66 3 1,046 09-23-22, 03:58 PM
  1966 Coronet 500 rear leaf springs richardmay2 3 13,427 07-18-17, 01:30 PM
  Seat belt bolts-Washers for the bolts and which ones get them?? 67RTBlue 4 5,123 09-03-16, 10:24 AM
  '68 Coronet 500 Exterior Trim Black JimKueneman 2 4,321 08-31-16, 10:49 AM
  Some Rear Driveline Restoration... TX67RT 15 9,954 10-30-15, 01:06 PM
Last Post: Warhawkfight34
  1969 Coronet 500 4dr trim and molding needed ffhtrod 2 4,188 09-21-15, 04:01 PM
Last Post: ffhtrod
  Rear qtr window VERTICAL chrome trim seals..and Something I'm calling channel rubber.. TekHousE 8 5,847 09-03-15, 11:31 PM
