		How do I remove this piece of trim? It's the one markrd 23 D/S.  It's on a 68 coronet 440 2 door.   5821]
		Take the inner panel off, with the window rolled up and you can get to the clips then
		you should be able to use a panel pop tool and get it behind the clip. If not listen to 68 500. Its been a while since I finished mine so my memory fails me.
		Thank you for your answers.  I'll give it a try.
