Stud welder to fill trim holes
I need to fill the top trim holes on Dart, will this work?
Stayed up all night trying to decide if it will work or not, would like to sleep tonight.
[Image: th?id=JN.tqrQi3eRlvSBdV4OHp%2foZg&pid=15.1&P=0]
Drill a hole in a piece of test metal first.
You need to fill it? Got a picture of what u wanna do? You don't wanna use that to fill. Mig welder to fill.
Ok I get some pics
ThanksI'm no body man just thinking up ideas to fill these trim holes
I do have a mig just thought that would warp it
Nope - get some pics and I will give you pointers on how to do it. Mig welders are perfect for filling holes but I times I do TIG them. I have gotten very good at welding up rust holes with the mig - you zap it till you get a ball stuck and then use the ball as a heat sink and work around the hole. These were rust holes I stitched up with a mig.
5995]5996]
Bigger holes.......
5997]5998]5999]6000]6001]6002]
The ones on the side pillar are about 1/4 and below back glass are 5/16
Nice work Mark Smile
Was that a vinyl top car?
That's a bit further from a solid edge than I anticipated. There is some risk of warping. I would use a heat sink compound such as this one (this is the one I use - its reusable - just keep it wet)
http://www.eastwood.com/ew-anti-heat-compound-1-qt.html
This is a newer style I have not used before:
http://www.eastwood.com/coldshield-thermal-paste.html
To weld it, I would go down one heat setting than what is called for. Need to keep an eye on it - may need to go to rated heat.
Trick is to just zap it. Zap an edge, let it cool for a second, then zap right next to it using the first ball as a heat sink. Keep going around - you can fill about 2/3 of the hole and then finish it up - very small circular motion. If you are concerned about burning through then go all the way around the hole before you finish it - the welded part is much more difficult to burn through. It is pretty amazing how big a hole you can bridge with the mig. Certainly when you have about 1/8 inch hole left just finish it off. If you do it correctly after grinding all you will need is primer. Grind with a 36 grit sanding disk, although 24 grit can also be used. I use a 5 inch disc. Use 0.025 wire - thicker wire (0.030) can be used but its not as good or easy.
Practice..........
ws27 Wrote:Was that a vinyl top car?
Yes white top, white interior, Turbine bronze, I like the look and I have all the trim plus some and a shame to leave off but car will be outside most all year round so I don't think it would be a good idea to put one back on.
  Last piece of the puzzle - 1966 Coronet convertible window trim CoVert66 3 1,046 09-23-22, 03:58 PM
  convertible rear seat trim bike_guy123 3 25,606 06-30-18, 07:17 PM
Last Post: bike_guy123
  '68 Coronet 500 Exterior Trim Black JimKueneman 2 4,321 08-31-16, 10:49 AM
  1969 Coronet 500 4dr trim and molding needed ffhtrod 2 4,188 09-21-15, 04:01 PM
Last Post: ffhtrod
  Rear qtr window VERTICAL chrome trim seals..and Something I'm calling channel rubber.. TekHousE 8 5,847 09-03-15, 11:31 PM
  How do I remove this piece of trim? Kj3800 3 4,234 04-11-15, 09:37 PM
Last Post: Kj3800
  1966 & 1967 Dodge & Plymouth B-Body Front Windshield Trim thebankerstoy 0 3,719 12-30-14, 12:20 AM
  Suggestions for Trim shop idougal 1 3,288 12-10-13, 09:31 AM
Last Post: Warhawkfight34
  1969 rear window trim? Warhawkfight34 1 3,194 10-31-13, 08:42 PM
Last Post: rip
  Finding holes for trim pieces on body after paint SmartPatrol 2 3,323 10-31-13, 05:32 PM
