Threads: 2
I noticed today that the front vertical edge of my driver's side window is out of it's "track" opposite the vent window. I also noticed a small hole in forward edge/top of the glass. It looks like maybe a small horzontal pin goes in there to hold the window in the vertical track as it rolls up and down. Did I lose a pin or something that goes thru sideways thru the glass to hold it in the track? Anyone know how to fix it?
Thanks,
Mark
Threads: 67
You will need to remove the glass and replace the glass channel pieces - here is what you need. It's a pretty intense job - I'll help walk you thru it if you want to tackle it.
http://www.rtspecialties.net/proddetail....od=2932230 - ignore the description in this link (confusing) - the parts you see in the pic are correct.
Threads: 2
I will order these and get back with you. Do you have a tele # I could call you. I am assuming I've got to take the door panel off, but a walk thru would be great or a you tube video ( I doubt one exists)?
Threads: 67
I dont have a video - I'll PM you.
