Window Regulator
I have a Great Dale House Car that was built on a 1965 dodge coronet and some pre-66 dodge truck frame.
11885
The window cranks are getting unusable.
Does anyone recognize this window regulator?
1188611887
It could be from any pre-66 vehicle (Probably 1965 Coronet, pre-66 Dodge truck, Caddie, or Olds). It looks the main body is OK. The steel looking cylinder gears are about stripped.
1188911888
Any help would be appreciated!
I bet it can be fixed in the right hands. I have never seen that design before.
Maybe these guys can help?
http://www.then-now-auto.com/window-regu...pair-kits/
[Image: antique-window-regulator-repair-kits-the...90x250.jpg]
What are the dimensions? Maybe we can find one that will be close enough to work?
Absolutely worst case I may be able to make one that will work. I like challenges............
Thanks! We added some JB weld to fill in the gaps in the gears and I just put it all back together again.
Now that I've taken it apart and understand how it all works, it appears to be installed 1-2" too low, which would be a nightmare to fix and keep the crank where it needs to be. It worked great once it started... until I went to show the wife. The glass and gears went wonky.
She approved an electric system because it would be much easier to install. I'd like to keep it manual, but I don't want to do triginometry to figure out the installation. Does anyone know of a manual window regulator that is all vertical like a AutoLoc Flat-Glass Power Window Conversion Kit or Electric Life EL1000-K Flat Glass Power Window Kit.
  68 Vent Window DELETE - please help!! 68moreDoor 1 10 03-27-25, 05:19 PM
  67 coronet window fuzzies D1esel 2 14 03-24-25, 09:07 AM
Last Post: D1esel
  Quarter window rebuild bike_guy123 18 28,383 02-08-18, 02:13 PM
  67 Coronet power window question Lipers1 8 5,324 10-11-15, 01:47 AM
  front window 1967 dodge coronet 440 Markfive 3 3,989 09-16-14, 11:32 AM
  66 / 67 Coronet Quarter window regulator refurbish and install Hibbing_Coronet_500 4 4,951 02-15-14, 12:33 PM
Last Post: mrconvertible
  upper side window trim felt? markbob@ameritech.net 8 4,980 05-29-13, 11:51 PM
Last Post: stamm321
  can't find window washer pump wire on 1967 coronet 440 boydsdodge 9 6,417 05-22-13, 07:37 PM
  66 Front Window Question stamm321 2 3,577 05-07-13, 01:12 AM
Last Post: stamm321
  Voltage regulator update honcho 0 2,695 03-24-13, 04:56 PM
