1965 Coronet 4 speed lubrication confusion
When I first purchased my Coronet, the shop that I used to flush and replace all fluids put Dextron 3 into the gearbox saying that was the required lubricant after research. I am planning on taking the car on a fairly long trip soon and am uptight that it doesn't have 90w gear oil. Should I be? Thank you!
Yes you should be uptight. It should have GL4 gear oil in it. Plan on ordering it online I wasn’t never able to find it locally.
The shop was right. Automatic tranny fluid is correct – see the pic below from the 65 factory service manual.
Growing up, we had a 65 Belvedere 6 cyl 3 speed on the column. My dad put gear oil in it and couldn’t shift it. Had to put ATF in it.
11907
Thank you!
I always believed that was for racing or very cold weather. Atf
67r/t4speeder Wrote:I always believed that was for racing or very cold weather. Atf
I always found it to be a confusing topic. For 69, they show either ATF or multipurpose gear oil - see below. I talked to Jamie Passon and he said to use ATF.
11908
Who has tried atf? , curious how it reacted myself.
67r/t4speeder Wrote:Who has tried atf? , curious how it reacted myself.
I tried it once, it kept trying to shift by itself. That just took all the fun out of it for me. HAHA!!
ATF in an 833 4-speed will eat the countershaft. Always go with gear oil.
I worked for Mopar dealers from '68-'72... Type A/B/Dexron was the factory fill.
  67 coronet window fuzzies D1esel 2 15 03-24-25, 09:07 AM
Last Post: D1esel
  Speaker confusion Kingspagetti 5 1,954 10-28-23, 09:32 AM
Last Post: Histoy
Last Post: revel68
  4 speed crank mike1968rt 5 10,717 10-24-18, 06:27 PM
Last Post: dag1969
Last Post: R/T XTC
Last Post: Just Wheels
  1949 dodge coronet new guy wafo63 9 6,221 04-12-16, 06:45 PM
Last Post: wafo63
