1967 440 Clutch Fork Pivot
Hi everyone, been quite awhile since I posted on here. I was hoping someone on here could help me. I have a 67 Coronet, originally a 383 4 speed car. I've owned it for 43 years and thought it was time to get it back on the road. It had a 440 when I purchased it, I installed a 383 some years later, all of this was years ago. Anyway , I installed a 440 that I had laying around, had the 4 speed went thru. It has the 2843234 11 inch bellhousing that was used only in 67 B and C Body 440 cars. m I got all of the clutch linkage installed, everything looked good till I tried to put the clutch adjustment rod in. It sits at about a 45 degree ancle. I called Brewers, ane and he told me that the C and B Body used a different fork pivot. I looked up the part numbers in my 67 Parts book and it shows the same part number for both. Anyone have any pictures of the 67 440 pivot? I tried to delete some incorrect letters that I've typed but can't on here, whats up?
https://www.passonperformance.com/produc...ot-bracket
Maybe some help??
I agree that the parts book does not show any difference. Can you post some pictures?
Thanks for the replies. The 67 440 B and C Body used different clutch fork pivots. I found the right one and everything lines up perfectly now.. Thanks!
lemondana Wrote:Thanks for the replies. The 67 440 B and C Body used different clutch fork pivots. I found the right one and everything lines up perfectly now.. Thanks!
Great to hear! I just didn't see that in the parts book.
  Relays for headlights 1967 stonehengeheels 3 3,110 03-08-16, 11:43 AM
  1967 440 Harmonic Balancer TX67RT 7 5,849 01-11-16, 10:59 PM
Last Post: TX67RT
  1967 500 Hood latch? Smoke4570 13 7,010 12-11-15, 12:56 PM
  1967 Headlight Switch stonehengeheels 6 4,976 06-19-15, 01:24 AM
  1967 coronet fiberglass front bumper Stage III 0 2,654 06-09-15, 07:43 PM
Last Post: Stage III
  front window 1967 dodge coronet 440 Markfive 3 3,989 09-16-14, 11:32 AM
  Driveshaft / U-Joint Tech 1967 Coronet 500: SUMMARY Hibbing_Coronet_500 16 8,715 09-10-14, 02:10 PM
  Driveshaft / U-Joint Tech 1967 Coronet 500 Hibbing_Coronet_500 44 18,126 08-21-14, 08:31 PM
  1967 Coronet tunes. Hibbing_Coronet_500 7 6,179 07-28-13, 04:18 PM
Last Post: Copper67440
  can't find window washer pump wire on 1967 coronet 440 boydsdodge 9 6,417 05-22-13, 07:37 PM
