08-24-14, 01:54 PM
I want to update you and give a summary of the dreaded Modulating driveline vibration at highway speeds that I have been trying to resolve.
At first the vibration was slight and not too bothersome.
I replaced both leaf springs and bushings to correct ride height and restore comfort. That made the vibration worse!
I replaced the u-joints. That made the vibration more worse!
I messed with driveline angles with some positive results, but not totally fixed.
I moved forward to the transmission, I replaced the rear bushing. This bushing showed some big time wear!
I inspected the transmission yokes internal splines with a flashlight and noted deep wear at where the tailshaft ends inside the yoke. Once everything was reassembled.
The looseness at the yoke at the output of the transmission was reduced by 50%.
I remeasured my drivline angles and noted that I could remove those axel shims and return the rear end to its stock angular location.
I fueled the car and me and the wife went to a car show about 40 miles away and noted the best ride ive had in that car at 65 mph! Ever!
The ride back was not as good. Unsure if a lighter car due to fuel consumption? Maybe wear on the new bushing?
The vibration is back........
My thoughts are this:
Replace the transmission yoke? Or replace transmission yoke and driveshaft as a assembly?
My observation on the dreaded modulating drivline vibration is: Wear, Looseness, With slight misalignment.
Wear makes parts loose, Loose parts can move, If loose parts can move? Will they maintain there rotational centerline.
The answer is no.
The answer is no.
