Rear tire size fitment on a 67
Anyone running 8 inch wheels with 4.5 back space on the rear with 255/60/15 or 255/70/15 ?
Thanks Jim
I tried the 8 inch 4 1/2 inch backspace wheel with the M/T ET Street Radials 255/60/15 in my bone stock 67 Coronet 500 wheel well. It was a no go - turning the tire would rub the aluminum trim in the wheel well. I was not going to trim it - car is too nice. Went with a 7 inch 4 1/4 inch backspace but in retrospect I believe the 7 inch with 4 inch backspace would have been fine. The 8 inch made the tire section width too thick - the 7 inch rim makes the section width smaller.
18X8, 5 x 4.5 bolt pattern, 4.50 in. backspacing with 235/55-18 on my '66- 3/8" back clearance and have not measured front but it is not touching sitting idol.
5173
[/URL]
markz Wrote:I tried the 8 inch 4 1/2 inch backspace wheel with the M/T ET Street Radials 255/60/15 in my bone stock 67 Coronet 500 wheel well. It was a no go - turning the tire would rub the aluminum trim in the wheel well. I was not going to trim it - car is too nice. Went with a 7 inch 4 1/4 inch backspace but in retrospect I believe the 7 inch with 4 inch backspace would have been fine. The 8 inch made the tire section width too thick - the 7 inch rim makes the section width smaller.
Thanks Markz
I was thinking the 8 inch wheels might be to wide.
Jim
You can use a 8" wheel but go with a 5" backspace for a 275
Just remember you can always push the tire back out so you might go with a 5 1/2" BS
  Rear Wheel/Tire Size Advice MrV8JF 1 226 05-15-23, 09:36 AM
Last Post: revel68
  Max wheel and tire combo for a ´67 Irores 5 28,840 07-14-18, 04:48 PM
  Wheel stud Knurl size Hibbing_Coronet_500 2 3,705 06-09-16, 07:30 PM
Last Post: Dionisio -C-
