Wheel stud Knurl size
I ordered a Goodson wheel stud swedge cutter. I am going to go with longer wheel studs as I am running a 1/4 inch spacer on the front because the wheels have the wrong backspace.
My 67 has the 10" front drum. Anyone know the knurl diameter by chance?
After I get the 5 wheel studs changed out in the front. I will have a swedge cutter for sale.
Only 5?
The previous owner at sometime in history tried to remove the left handed thread wheel studs and ruined the hub.
So I only have 5 original wheel studs to remove.
Thanks in advance
Usually it goes by stud size and that would be 1/2"
Yeah, I have 1/2 x 20 studs
  Max wheel and tire combo for a ´67 Irores 5 28,841 07-14-18, 04:48 PM
  Magnum Wheel Width Xtro 8 6,299 07-28-17, 07:48 AM
Last Post: beefman
Last Post: Dave Wallace
Last Post: Dionisio -C-
  Rear tire size fitment on a 67 BooBoo 15 12,828 11-04-14, 06:22 PM
  A12 Coronet what size flywheel 67r/t4speeder 6 4,830 10-20-14, 08:55 PM
Last Post: elevatorman
  1969 Coronet 500 Tire Size BostonElfjr 12 9,479 03-31-14, 03:38 PM
Last Post: Mopars & Missiles
  HOW TO MEASURE WHEEL RIM OFFSET & BOLT CIRCLE harold prentice 5 5,631 12-10-13, 11:37 PM
