A12 Coronet what size flywheel
Starting to gather up all the parts needed to get a A12 back on the road and wanted to verify if it takes a 10.5 or 11 flywheel. There are both in trunk of car.
67r/t4speeder Wrote:Starting to gather up all the parts needed to get a A12 back on the road and wanted to verify if it takes a 10.5 or 11 flywheel. There are both in trunk of car.
I would bet money, it's an 11!!
So would I. You can also use a 10 1/2" clutch on an 11 inch flywheel to reduce some reciprocating weight, making it easier to Banging Gears.
10.9 clutch on a 10.5 flywheel even better, thats what I have. Cheater clutch they use to call it or scalloped.
As far as A12 I would like to know what came stock though.
+1 to that.
My moneys on 11"
67 R/T 440ci 4spd
[SIGPIC][/SIGPIC]
11" fur sure
  1965 Coronet 4 speed lubrication confusion finz68 15 34,680 11-01-23, 06:33 PM
Last Post: Krooser
  Rear Wheel/Tire Size Advice MrV8JF 1 224 05-15-23, 09:36 AM
Last Post: revel68
Last Post: dag1969
Last Post: R/T XTC
Last Post: Just Wheels
  Wheel stud Knurl size Hibbing_Coronet_500 2 3,705 06-09-16, 07:30 PM
  1949 dodge coronet new guy wafo63 9 6,221 04-12-16, 06:45 PM
Last Post: wafo63
Last Post: JohnS
