06-22-13, 02:17 PM
Liquid dish soap is what I've used since the sixties. Cheap & readily available.
Gas tank rubber seal istall
06-22-13, 02:17 PM
06-23-13, 04:35 PM
(This post was last modified: 06-23-13, 04:43 PM by thebankerstoy.)
SmartPatrol Wrote:BTW... I dunno about you, but I tried replacing my tank, tank to body pad, with a new strap and j bolt. What a freaking nightmare this was. The J bolt that Layson's restoration supplied wasn't anywhere near the same as the original one. The new strap was creased the opposite way it should;ve been, and the tank wouldn't allow the old strap to wrap around it easily. I literally had to use a scissor jack and all of my might to wrap the old strap and J bolt up into the car. The pad wouldn't fit. It was Beeeeeyond tight. Hello Josh, I won't get into what I think about the folks that work at Layson's, but if they sold you a gas tank strap mounting J bolt that looks like the one below, I can see why you had trouble installing your gas tank strap, because that style J bolt is absolutely NOT correct for the 1966 and 1967 Dodge and Plymouth B-Body cars! The correct J bolt for the 1966 and 1967 B-Body cars looks like this and as far as I know, nobody is reproducing it, so if your original is missing, you will need to find a used one somewhere. With the correct J bolt in place, you shouldn't have any issues installing a new insulator pad between the top of the fuel tank and the bottom of the car. Richard
06-23-13, 06:49 PM
thebankerstoy Wrote:Hello Josh,Richard, the top of your axle is dusty...shame on you.
06-23-13, 09:22 PM
You really need to post a sunglasses required alert next time Richard. Haha
06-23-13, 10:36 PM
He also needs to paint the axle tube the correct color. That black is 1.2pigments too dark for a 66..
Laysons has the correct color he needs...
06-23-13, 10:38 PM
Believe it or not guy's, that picture above isn't of my Coronet! Yep, there's another sick individual out there that loves bright yellow 66-67 Coronet's as much as I do!!!
06-23-13, 10:44 PM
(This post was last modified: 06-23-13, 10:47 PM by thebankerstoy.)
67440Dodge Wrote:He also needs to paint the axle tube the correct color. That black is 1.2pigments too dark for a 66.. Oh MAN Mike, that's your best joke yet buddy!! Layson's having the correct ANYTHING for a Mopar!!!! I'm laughing so hard right now that I'm almost crying!!! It's either your joke, or maybe I'm just remembering the last transaction that I had with them years ago!!! Opps, I guess that I'm not being "politically correct" with those comments huh? Blonde Richard
06-23-13, 11:22 PM
Maybe his stint in jail set him on the correct path?
06-24-13, 01:41 AM
67440Dodge Wrote:Maybe his stint in jail set him on the correct path? Yep, I'm sure he's a completely different guy now......................and I also believe in the Tooth Fairy, the Easter Bunny and honest politicians! Richard
Viton vs Rubber for rear main | 67440Dodge | 17 | 943 |
05-02-23, 02:31 PM Last Post: 67440Dodge |
Rear Main Seal-Opinions wanted | 67RTBlue | 19 | 28,230 |
08-21-18, 09:49 AM Last Post: 67RTBlue |
Fuel tank vents | Stargazer | 11 | 8,084 |
08-04-16, 10:28 PM Last Post: metaldad |
Fuel tank to fuel line rubber hose picture | 67RTBlue | 12 | 6,972 |
01-27-16, 02:25 PM Last Post: Racer Brown |
Has anyone Added an in tank fuel pump For carby setup instead of standard electric | Jpr777 | 5 | 3,272 |
10-08-15, 06:56 PM Last Post: Drag-Net |
Users browsing this thread: |
2 Guest(s) |
