Gas tank rubber seal istall
I,m replacing the seal that goes where the filler tube goes into the tank . That big Donut looking thing . Any tricks to doing this . Should I grease it up or install it dry ? Thanks . BooBoo
LIL WD-40 won't hurt on the neck when sliding back in but that's about it. Easy job.
Try KY jelly....oops, did I say that?
4264door Wrote:Try KY jelly....oops, did I say that?
Good.. Rich can label someone else the pervert now!!
LOL! As Maxwell Smart used to say..."And loving it"! LOL
BTW... I dunno about you, but I tried replacing my tank, tank to body pad, with a new strap and j bolt. What a freaking nightmare this was. The J bolt that Layson's restoration supplied wasn't anywhere near the same as the original one. The new strap was creased the opposite way it should;ve been, and the tank wouldn't allow the old strap to wrap around it easily. I literally had to use a scissor jack and all of my might to wrap the old strap and J bolt up into the car. The pad wouldn't fit. It was Beeeeeyond tight.
....or vasoline jelly!!
67440Dodge Wrote:Good.. Rich can label someone else the pervert now!!
That stigma will take a looooong time to go away. LOL
I use silicone spray.
Thanks Ya'll ! BooBoo
  Fuel tank vents Stargazer 11 8,084 08-04-16, 10:28 PM
Last Post: metaldad
  Fuel tank to fuel line rubber hose picture 67RTBlue 12 6,972 01-27-16, 02:25 PM
Last Post: Drag-Net
