rear sway
Hey folks, is it worth to get a rear sway??? My ride handles great,but when you get down on her, she's all over the road. Wondering if a rear sway would keep her straight or just keep my foot out of her (not) Thanks
A rear sway bar for your car will certainly help, along with a good front sway bar with new bushings.
A big difference noticed, well worth it.
They do make a big difference, but my only complaint is that you get sideways whiplash when you go over an uneven bump in the road. What are you running for shocks, tires, and front sway bar, front end rebuilt?
Noticed a difference first fast corner I took, Thumbs up
ws27 Wrote:They do make a big difference, but my only complaint is that you get sideways whiplash when you go over an uneven bump in the road. What are you running for shocks, tires, and front sway bar, front end rebuilt?
Damn Rich you must have bigger bumps than we have around here and we have some whoppers.
Yea I have front sway,love it. 255x15x8 in rear. KB shocks all around. How hard is it to install and a good place to purchase one. Thanks again Todd
Install was a breeze got mine from PST they're on the web
What's your budget?
67r/t4speeder Wrote:Damn Rich you must have bigger bumps than we have around here and we have some whoppers.
I take it you've never driven on a New England road have you? We have frost heaves and pot hole crops, some years yield better (or worse depending on glass half full/empty) than others.
Last Post: revel68
Last Post: Dionisio -C-
  Rear Sway bars on a WAGON??? rolling18 8 6,066 02-14-15, 02:15 PM
  rear axle coronet 69... o.dima 4 4,230 11-12-14, 06:44 PM
Last Post: o.dima
