rear axle coronet 69...
my 69 coronet has a 8 3/4" axle, does anyone now if the both axle shafts are similar?
Left to right they are. I've come across a few that were swapped left to right.
ok, i think that is the reason why i have clockwise wheel bolts on the driverside and counterclockwise on the passenger...
If you look closely, the end of the stud is usually marked with a L or R.
yes you are right, someone has swapped the axle shafts in the past...
  67 coronet window fuzzies D1esel 2 14 03-24-25, 09:07 AM
Last Post: D1esel
  Axle bearings, seals, etc.. Coronet67500 2 13 01-24-25, 05:34 PM
Last Post: Coronet67500
Last Post: Krooser
Last Post: revel68
Last Post: dag1969
