07-20-21, 11:45 PM
I need to start work on the front end in stages. What would be the first step? Upper and Lower ball joints? Thanks.
1967 Front End Work
07-20-21, 11:45 PM
07-21-21, 01:21 AM
Id go lower ball joints, strut bushings and lower control arm bushings first. Then second upper ball joints and upper control arm bushings.
07-21-21, 10:34 AM
Have you had an inspection done?
Jeff is right start down low and work your way up. Only replace it if needed though.
07-21-21, 11:20 PM
No inspection, just wobble and tire scalloping. Just had a tire balance and same thing still happening. This very helpful. Thank you.
07-22-21, 08:08 AM
Just don't buy one of those all in one kits from Kanters/PST/Just Suspension.. cheaply made Chinese/Taiwanese parts that last as long as old fuel line and ethanol. Moog parts are still available, I've got a list of part numbers on the site to use.
If you're scalloping I'd look at shocks as well..
07-22-21, 09:42 PM
Where would I find that list 67440?
07-23-21, 12:10 PM
stonehengeheels Wrote:Where would I find that list 67440? https://www.dodgecoronet.com/coronet/sho...sion-Parts
07-24-21, 10:55 AM
Mopars & Missiles Wrote:https://www.dodgecoronet.com/coronet/sho...sion-Parts Thanks!! If your local auto parts store can't get them, believe it or not Amazon used to carry them.
1967 Coronet 'Restoration' | Piper | 29 | 207 |
07-27-24, 05:12 PM Last Post: juan a. |
Front End Alignment Shop for 1967 Coronet | 440net | 2 | 15 |
05-29-24, 04:14 PM Last Post: 440net |
1967 Coronet Hemi Value | strangleholdracn | 7 | 1,574 |
04-02-22, 08:03 PM Last Post: thebankerstoy |
1967 Coronet rebuild thread. | Piper | 25 | 25,405 |
11-11-19, 02:20 PM Last Post: Piper |
Happy Birthday 1967 Coronet. | Hibbing_Coronet_500 | 9 | 5,225 |
04-16-17, 12:48 PM Last Post: Racer Brown |
Guess Valvoline Racing Oil don't work........... | markz | 3 | 2,888 |
10-23-15, 07:16 PM Last Post: markz |
1967 coronet front fiberglass bumper | Stage III | 2 | 3,462 |
07-01-15, 09:03 PM Last Post: markz |
1967 R/T rear brake drum | hemibro | 12 | 8,046 |
11-26-14, 09:47 PM Last Post: markz |
front end/ engine swap question...... | bike_guy123 | 7 | 4,661 |
06-05-14, 10:55 PM Last Post: honcho |
Got the front end in! | Warhawkfight34 | 6 | 3,696 |
05-29-14, 08:11 AM Last Post: Warhawkfight34 |
Users browsing this thread: |
1 Guest(s) |
