front end/ engine swap question......
I have a 66 coronet convertible that I have had for a number of years and never and driven.....it is a 383 automatic car.....it has been in my garage and on a rotisserie for almost all the time I have owned it.....now it is off and ready to be put back together, but I don't have the funds to get the 383 done at this time....
Here is my question....
I have a 1967 4 door coronet that runs and drives great....it is a 318, automatic.
can I just swap out the front ends....ie, k frame and suspension stuff? if not, why? I was thinking this would be an easy way to enjoy the convert for the summer....
thanks for any advice.....
Mike in MN
Yessir.. Everything should bolt up. K-frames are the same, suspension pieces are the same. Only snag you may run into is if one car has manual steering and the other has power. Columns are different between the 2.
You can unbolt the engine/trans from the 67 and bolt it right into the '66
SE 4-door looks pretty nice
Vert looks sweet too Smile
thank you for the kind words.....I already have the big block K-frame in the car....the 318 will just bolt up to that is what you are saying? both cars were power steering cars...
If that is the case, thank you MOPAR gods....you have put wind back in my sails.....I am dying to drive the vert!
Converts are cool, nothing like having the wind in your hair, well, some of us have less then others!!!!!!!!!!
For 66-70, the K-frames are the same for small to big block. So the 318 will drop right in to the 'vert and bolt up.
Hey bike guy,good luck on the restore man, got questions or need help,holler at me and welcome to the site Todd
  Front End Alignment Shop for 1967 Coronet 440net 2 13 05-29-24, 04:14 PM
  1967 Front End Work stonehengeheels 7 2,685 07-24-21, 10:55 AM
Last Post: MarkMopar
  Disc brake question for my 67 Piper 36 30,564 04-27-19, 08:22 PM
  Old question with a twist sirjustice 2 15,075 12-13-17, 01:04 AM
  Recommend engine swap shop fitzyb5 2 2,937 10-13-17, 11:25 PM
Last Post: Dingusboy
  Engine problems all opinions welcome. Warhawkfight34 20 8,227 08-22-17, 08:23 AM
Last Post: Warhawkfight34
  Looking for 67 R/T engine bay pictures jworz71 12 8,387 12-19-16, 11:13 PM
Last Post: jworz71
  Question regarding Coker tire and the BF redline radials 67RTBlue 3 4,174 11-23-16, 02:34 PM
