Old question with a twist
Well seems that all the threads that I can find about wheel/tire size are mostly focused in the rear end. Now, I know that a I can fit a 275/60R15 in a 8'' wide wheel IF it is at least 4.5 in backspace.
But! what about the front end? I have a couple of 245/60R15 Cooper Cobra's and I'm wondering IF this could fit.
BTW, I just can't test by installing them because I haven't get a set of wheels.
Cheers!
What ride have you got?
I use to run B.F.G. Radial T/A's in the P235-60R-15 size on the front and rear of my 1966 Coronet 500 which is the same basic car as your 67 Coronet 440 and I had no issues with them on 15 x 7 American Racing Champ 500 wheels on the front and rear as shown below in some older pictures of my car during and after I restored the car back in the early 1990's. That combination was as wide as I felt comfortable with on my car on the front and rear with those Champ 500 wheels, but you might be able to run those slightly wider P245-60R-15's on your car if you're extremely careful with the back spacing on whatever wheels you end up purchasing.
[Image: 1966Coronet500-paintandbodywork--4.jpg]
[Image: 1966Coronet500-afterrestorationi-1.jpg]
[Image: 1966Coronet500atPRPin1993-instaginglanes.jpg]
[Image: 1966Coronet500atPRPin1993-leavingstartin...arview.jpg]
Last Post: MarkMopar
  Disc brake question for my 67 Piper 36 30,564 04-27-19, 08:22 PM
Last Post: Dingusboy
  Question regarding Coker tire and the BF redline radials 67RTBlue 3 4,174 11-23-16, 02:34 PM
  Tough question hopefully someone can answer! Warhawkfight34 3 3,257 02-23-16, 04:10 PM
Last Post: Warhawkfight34
  Trunk Spatter Question OldSkool 8 4,843 10-17-15, 07:51 PM
Last Post: dartforforty
  Washer Bottle question OldSkool 9 4,355 10-09-15, 11:26 AM
  Dodge Challenger Question Histoy 3 3,387 08-04-15, 02:14 PM
Last Post: Histoy
  68 383-2 block vin #s question slimert 6 4,270 04-08-15, 10:56 AM
Last Post: slimert
  trans cooling question Piper 8 4,309 08-11-14, 10:54 PM
Last Post: Piper
