[TR="class: totals total"]
[/TR]
[TR="class: part0, bgcolor: #F0F0F0"]
[TD][TABLE="class: layout, width: 700"]
[TR]
[TD="class: left"]RAYBESTOS Part # 1938R {#1938} Professional Grade
Front; 11" Brakes; Cast Iron Drum[/TD]
[TD="class: right, align: right"][/TD]
[/TR]
[/TABLE]
[/TD]
[TD="class: center, colspan: 2, align: center"]$69.89[/TD]
[TD="class: center, align: center"][/TD]
[TD="class: right, align: right"]$139.78[/TD]
[TD="class: center, align: center"][Image: Remove.gif][/TD]
[/TR]
[TR="class: pt"]
[TD][Image: Gear.gif]Brake/Wheel Hub : Brake Shoe[/TD]
[TD="colspan: 2"][/TD]
[TD="colspan: 3"][/TD]
[/TR]
[TR]
[TD="class: left"]WAGNER Part # PAB335R {#PAB335} ThermoQuiet
Rear; 11 x 2-1/2" Brake; Riveted[/TD]
[/TR]
[/TABLE]
[/TD]
[TD="class: center, colspan: 2, align: center"]$21.79[/TD]
[TD="class: right, align: right"]$21.79[/TD]
[/TR]
[TR="class: totals subtotal"]
[TD="colspan: 4"]Subtotal[/TD]
[TD="class: right, align: right"]$161.57[/TD]
[TD][/TD]
[/TR]
[TR="class: totals destination"]
[TD="colspan: 5"]Country: Postal Code: [/TD]
[TD][/TD]
[/TR]
[TR="class: totals shipping, bgcolor: #F0F0F0"]
[TD="colspan: 4"]Shipping: from United States (You should receive by December 8)[/TD]
[TD="class: right, align: right"]$234.79[/TD]
[TD="bgcolor: white"][/TD]
[/TR]
[TD="colspan: 4"]Total
Story of my life.....living in NZ[/TD]
[TD="class: right, align: right"]$396.36
[/TD]
[/TR]
[/TABLE]
I see you ordered front drums. Did you need front or rears?
Oh I just did the diff, from 4:11 to 3:23, finally found a 3:23 in Canada... so put new axle bearings in as well, and noticed rear pads were low, then found out drums were 80,000 under on one and 100,000 over on the other, so putting pads in will be difficult...time for new rear drums...
Pretty sure they are 11" and 2 1/2 pads in the R/T rear
1967 R/T rear brake drum
Hi
I need some help please..
What size will my 1967 R/T coronet have in rear brake drums? 11" ??
And does anyone know where in US you can buy some? I'm in New Zealand.
Thanks
Try these guys https://www.jimsautoparts.com/brake.htm
yes it had 11s stock
You can also try Craig in New York.
1-516-485-1935 He has lots of obsolete brake parts.
ws27 Wrote:You can also try Craig in New York.
This the guy that is always at Carlisle with the handwritten signs and brake/suspension parts all over the table?
You really need to measure the old ones. Measure the inside diameter of the drum to know the diameter of the drum and measure the width of the shoe to get the width. Do not measure the with of the drum - it will be wider than the advertised width of the brake drum.
Rockauto.com will probably be the cheapest. probably Chinese, but they work. I use them on the rear of my daughter's 67 Coronet 500. Those are 10 x 2 1/2. The price of those drums is under $40 each today. I believe that the 11 x 2/12 are similar in price. If shipping is really high, let me know if I can ship them to you cheaper. Rockauto has both 10 inch and 11 inch.
I've been to Auckland before - late 1990's. We used to have a paper mill not far from Rotorua.
67440Dodge Wrote:This the guy that is always at Carlisle with the handwritten signs and brake/suspension parts all over the table?
If it is I have nothing good to say so I won't say anything...........
Thank you so much markz
shipping will be more than drums lol
[TABLE="class: layout carttable, width: 1006"]
  1967 Coronet Hemi Value strangleholdracn 7 1,574 04-02-22, 08:03 PM
  1967 Front End Work stonehengeheels 7 2,685 07-24-21, 10:55 AM
  Coil over rear shocks for B bodies? stonehengeheels 8 5,145 12-09-20, 09:08 PM
  1967 Coronet rebuild thread. Piper 25 25,405 11-11-19, 02:20 PM
Last Post: Piper
  Disc brake question for my 67 Piper 36 30,564 04-27-19, 08:22 PM
  Happy Birthday 1967 Coronet. Hibbing_Coronet_500 9 5,225 04-16-17, 12:48 PM
