318 carb rebuild
Howdy guys. I have a 71 coronet with the 318 2bbl. My carb is starting to go bad and i need a rebuild. My ol buddy at napa told me there was many carbs and that i would need the number from the carb and it would probably be a pain to find it. My question is, can i look up my vin or anything to find the carb that they used? thanks a lot guys
carburetors are a foreign language to most people at parts stores. a quick search of rock auto turned up these-
[TABLE="class: main"]
[TR="class: part1"]
[TD="class: alternate1"][TABLE="class: parts"]
[TR]
[TD="class: left"][TABLE="class: layout"]
[TR]
[TD="class: partlayout"]STANDARD MOTOR PRODUCTS Part # 1597 {Click Info Link for Alternate/OEM Part Numbers3514242, 3744795, 69500, 9811, CK5382, CK5492, CK5562, CT1097, CT904, CT904A, CT904B} Carburetor Type: Model BBD; Carter 2 Bbl. Carbs
Carburetor Kit 2 BBL,CARTER equipped - EXC EXP[/TD]
[/TR]
[/TABLE]
[/TD]
[TD="class: right"][Image: prevIMGsmall.gif][Image: 1597photo%20primary__ra_t.jpg][Image: nextIMGsmall.gif]
[/TD]
[/TR]
[TR]
[TD="colspan: 2"]* Stocked in outlying warehouse--shipping delayed up to 1 business day[/TD]
[/TR]
[/TABLE]
[/TD]
[TD="class: center leftrightborder boldfont priceonly alternate1"]$19.82[/TD]
[TD="class: center boldfont leftrightborder pricebreakdown alternate1"][/TD]
[/TR]
[TR="class: part1"]
[TD="class: alternate1 center"][/TD]
[/TR]
[TR="class: part0"]
[TD="class: alternate0"][TABLE="class: parts"]
[TR]
[TR]
[TD="class: partlayout"]STANDARD MOTOR PRODUCTS Part # 1420B {#4267092} Holley 2 Bbl.
Carburetor Kit 2 BBL,HOLLEY equipped[/TD]
[/TR]
[/TABLE]
[/TD]
[TD="class: right"][Image: prevIMGsmall.gif][Image: 1420Bphoto%20primary__ra_t.jpg][Image: nextIMGsmall.gif]
[/TD]
[/TR]
[TR]
[/TR]
[/TABLE]
[/TD]
[TD="class: center leftrightborder boldfont priceonly alternate0"]$35.99[/TD]
[TD="class: center boldfont leftrightborder pricebreakdown alternate0"][/TD]
[/TR]
[TR="class: part0"]
[TD="class: alternate0 center"][/TD]
[/TR]
[/TABLE]
[TABLE]
[TR]
[TD="class: ygtvdepthcell"] [/TD]
[TD="class: ygtvtp"] [/TD]
[TD][url=javascript:YAHOO.widget.TreeView.getNode('livecatalog',459).toggle()]Fuel Filter[/url][/TD]
[/TR]
[/TABLE]
That's actually been the way since I started working on cars. Because the same model engine can come with carbs from Carter, Holley, Rochester, they need the number off the side of the carb to look up the correct kit. Also, over the years, the carb may have been swapped out for a different one. VIN won't help them, because back the VIN will only say what engine it has, not the carb it has.
Your buddy is doing you a favor actually. Napa lists 7 carb kits for your car.
http://www.carburetion.com/carbid.htm can give you some help on where to find the carb number.
If you can't find a tag with a number on it, take the carb off and clean the outside, it will also be stamped on the casting somewhere. If you have to, bring it in so you can relay numbers to the guy.
  Wiper motor rebuild mike1968rt 5 17,974 10-25-18, 05:20 PM
  Quarter window rebuild bike_guy123 18 28,383 02-08-18, 02:13 PM
  727 rebuild Tom66-500 13 8,570 04-12-17, 11:54 PM
Last Post: Tom66-500
  440 build questions. Intake,carb,torque converter? 67RTBlue 18 10,880 06-12-16, 11:24 PM
Last Post: BBishere2
  Needed: Carter 4329S rebuild kit (67 R/T) David Lee 3 3,775 05-04-16, 11:53 AM
Last Post: David Lee
  crate motor or rebuild original? R/T XTC 37 15,734 04-18-16, 10:43 PM
Last Post: R/T XTC
  New carb? Tom66-500 13 7,045 04-07-16, 12:10 PM
