fuel line angle
Can anyone tell me if the line coming out of the gas tank sending unit, should be a 45 or a 90 degree angle. I need to get a new sending unit but they advertise both different ones on ebay. This is for 67 Coronet with a 5/16 line. Unfortunatly my car is 200 miles from me so I can't check it myself. Thanks in advance.
Bulldog Wrote:Can anyone tell me if the line coming out of the gas tank sending unit, should be a 45 or a 90 degree angle. I need to get a new sending unit but they advertise both different ones on ebay. This is for 67 Coronet with a 5/16 line. Unfortunatly my car is 200 miles from me so I can't check it myself. Thanks in advance.
Could you please give us a little more information on what you're asking about?
If you're asking about the sending unit, I can't speak for the station wagon models, but all of the 2 and 4 door hardtop and sedan models use the same basic sending units that exit at the front end of the fuel tank in front of the backside of the rear differential. The sending unit has a small straight piece of steel tubing that allows it to be connected via rubber fuel line to the main section of steel fuel line that goes from the sending unit connection at the fuel tank up to the connection at the fuel pump. The only difference in the 66-67 B-Body sending units is their size, which from the factory was either 5/16", or 3/8".
As far as the main fuel line itself, most all aftermarker main fuel lines from the fuel tank to the fuel pump are sold as the one below is.
Summit Racing web page link for this fuel line.
http://www.summitracing.com/parts/rsd-rg...refilter=1
1967 DODGE CORONET Right Stuff Detailing Front to Rear Fuel Lines RGL6601S
[Image: r_noimage_100.gif]
$85.50
[Image: button-add-compare.gif]
Fuel Line, Front to Rear, Stainless Steel, 5/16 in., Chrysler, Dodge, Plymouth, Each
  • The part RSD-RGL6601S has an additional shipping charge of $19.00 per item due to its large size and/or weight.
Estimated Ship Date: 2/5/2013 (if ordered today)
  • [Image: emailthispageicon.gif] Email
View Similar Products
[Image: 1516.gif] Right Stuff Detailing Front to Rear Fuel Lines
Part Type: Fuel Lines, Tank to Pump Lines
Vehicle: 1967 DODGE CORONET Find out if this fits your vehicle
Brand: Right Stuff Detailing
Manufacturer's Part Number: RGL6601S
Product Line: Right Stuff Detailing Front to Rear Fuel Lines
Summit Racing Part Number: RSD-RGL6601S
Fuel Line Material: Stainless steel
Fuel Line Finish: Natural
Fuel Line Diameter: 5/16 in.
Quantity: Sold individually.
Right Stuff Detailing offers you the best fitting, most exactly reproduced fuel lines on the market. They utilize state-of-the-art CNC benders and automated end-forming machines that double flare lines with remarkable consistency. Right Stuff Detailing front to rear fuel lines are available in OEM steel or stainless steel.
Thanks Richard, you actually answered my question. I was talking about the small steel tubing.
Thank You, Dan.
Bulldog Wrote:Thanks Richard, you actually answered my question. I was talking about the small steel tubing.
Thank You, Dan.
Hello Dan,
Excellent, glad I was able to help. Cool
Below is a picture of the 3/8" fuel sending unit that I just installed on my 1966 Coronet 500. Your 5/16" sending unit should look the same except for the slightly smaller diameter steel tubing. The piece of tubing that you were asking about is the small piece located on the far right side of the round mounting plate on the right side of the sending unit. As you can see, it's a straight piece of tubing that allows you to use rubber flexible fuel line hose to connect the sending unit to the main section of steel fuel line that runs down the passenger side of the car up to the fuel pump.
[Image: 521RestorationsPartFG94B-1966-67Coronet3...gUnit1.jpg]
  Fuel tank vents Stargazer 11 8,084 08-04-16, 10:28 PM
Last Post: metaldad
  Fuel tank to fuel line rubber hose picture 67RTBlue 12 6,972 01-27-16, 02:25 PM
  Brake line question-passenger side line hump or no hump? 67RTBlue 2 2,934 01-07-16, 11:12 PM
  Fuel filler leaking cnmsales 5 4,006 12-18-15, 06:01 PM
Last Post: Drag-Net
Last Post: Billb66
  Fuel pressure of a stock 318 tkarman 2 3,148 05-22-15, 03:26 PM
Last Post: tkarman
  Setting dwell angle on 318 markbob@ameritech.net 3 4,080 08-03-13, 01:03 PM
