I'm workin' on the brakes in my '68 Super Bee. When I took things apart on the front brakes, I found that it did not have the self adjusters hooked up. Instead it had a star lock spring as in this photo
5596
I wanted to install the self adjusters so I bought some parts and put it together like this.5597 Obviously the eye on the self adjuster cable needs to go on the backing plate anchor. I've tried every method that I could think of to get that stinkin thing hooked up properly. The closest that I got to getting it into place (with the hook under the bracket at the bottom, and the eye on the anchor ) was by using a screwdriver as a lever and sliding the cable down the shaft of the screwdriver . The problem was that I couldn't get the tip of the screwdriver and the cable into the space between the shoe and the cable guide. Can I file a little off the edge of the cable guide? Anyone have a good suggestion for putting this %$%%#^ thing on?
Maybe I'd be better off using the star lock spring again and adjusting the brakes manually?
5596
