Rear end gear
Looking for opinions on rear gear ratio.my 69 bee 383 auto with what I believe is a mild build has 3:23 in it now.looking for a little more low end for fun.would I notice a real difference going to 3:55?has the 489 case.i have a 742 case I am thinking of swapping to the 3:55.thanks for opinions,David.
Are you planning on any freeway travels anymore? What tire size are you running?
Maybe buildling another case so you can save those3.23s its a great automatic gear set is a good idea
Thanks for the reply.i am running 245 60 15 tires.i run on hi way once in a while.no racing.the car just seems to have no end to the high end and not quite the low end I would like.whatever I do I will keep the 3:23 handy.my extra case has them as well.just looking for a little more stop light fun.
If you get annother whole chuck, then you can go back easy if you don't like them. Personally, I'd stay with 3:23s.
http://vexer.com/automotive-tools/speed-rpm-calculator
This tool might help you decide
That calculator is cool.Its pretty well on to what my car runs.
  Coil over rear shocks for B bodies? stonehengeheels 8 5,145 12-09-20, 09:08 PM
  Rear air suspension PSI? OldSkool 8 5,193 06-29-15, 03:40 PM
Last Post: 68 500
  Rear Seat Belts installed OldSkool 5 4,404 06-16-15, 11:54 AM
Last Post: OldSkool
  Shortened my first rear markz 7 4,431 03-30-15, 12:09 PM
  Rear sway bar install honcho 5 4,698 12-14-14, 05:52 PM
  1967 R/T rear brake drum hemibro 12 8,046 11-26-14, 09:47 PM
  Rear package tray installed OldSkool 9 4,988 11-19-14, 03:42 PM
  Rear air suspension? OldSkool 1 2,490 10-25-14, 05:54 PM
Last Post: Drag-Net
  Maintenance day and what's the trick to getting the rear seat out? OldSkool 3 2,849 09-27-14, 06:03 PM
