Shortened my first rear
Shortened my buddy's 8 3/4 for his 67 Barracuda. Started with a 65 C Body rear. Made the jig using a 2 inch hydraulic cyliner shaft. Also used an I beam to help hold the rear from moving when welding the pads and rear brace on.
Came out fair. Did good until the last operation (welding the brace extensions). If I had to do over, I would have done it differently to avoid welding the brace extensions after the ends were already welded on. It moved much more than I wanted but Strange tech support said it was fine.
5797]5798]5799]5800]5801]5802]5803]5804]5805]5806]5807]5808]5809]5810]
Great work !
Looks great - do you want to do my Dana for me?
Looks good! I saw last week in an email from jegs that they sell a kit for $500+ to shorten all the popular rears. I like that you made your own.
Good job!
Great job Mark!
That looks like fun
Nice work!
  Coil over rear shocks for B bodies? stonehengeheels 8 5,145 12-09-20, 09:08 PM
  Rear air suspension PSI? OldSkool 8 5,193 06-29-15, 03:40 PM
Last Post: 68 500
  Rear Seat Belts installed OldSkool 5 4,404 06-16-15, 11:54 AM
Last Post: OldSkool
  Rear sway bar install honcho 5 4,698 12-14-14, 05:52 PM
  1967 R/T rear brake drum hemibro 12 8,046 11-26-14, 09:47 PM
  Rear package tray installed OldSkool 9 4,988 11-19-14, 03:42 PM
  Rear air suspension? OldSkool 1 2,490 10-25-14, 05:54 PM
Last Post: Drag-Net
  Maintenance day and what's the trick to getting the rear seat out? OldSkool 3 2,849 09-27-14, 06:03 PM
  Rear Deck Cover OldSkool 4 3,024 08-26-14, 12:50 PM
Last Post: OldSkool
