Rear air suspension?
Ok, wicked newbie question. My 1965 Coronet has this air valve on the rear bumper. I poked around in my tech services manual and online and it's some type of rear air suspension. Could not find a lot of details on it. I will climb under tomorrow and see if anything connected to it. If there is, anyone know what the psi settings for it are? I expect it to have been ripped out, more curious that anything else. Thank you.
5033
What you have there is an air fitting for air shocks. If you look at the rear shocks and they have rubber bellows around them try airing them up. If you don't see the bellows then the shocks were removed to put a stock type shock back in. (no air shocks were installed at the factory)
  Coil over rear shocks for B bodies? stonehengeheels 8 5,145 12-09-20, 09:08 PM
  Rear air suspension PSI? OldSkool 8 5,193 06-29-15, 03:40 PM
Last Post: 68 500
  Rear Seat Belts installed OldSkool 5 4,404 06-16-15, 11:54 AM
Last Post: OldSkool
  Shortened my first rear markz 7 4,431 03-30-15, 12:09 PM
  Rear sway bar install honcho 5 4,698 12-14-14, 05:52 PM
  1967 R/T rear brake drum hemibro 12 8,046 11-26-14, 09:47 PM
  Rear package tray installed OldSkool 9 4,988 11-19-14, 03:42 PM
  Maintenance day and what's the trick to getting the rear seat out? OldSkool 3 2,849 09-27-14, 06:03 PM
  Rear Deck Cover OldSkool 4 3,024 08-26-14, 12:50 PM
Last Post: OldSkool
