1967 Front End Work
I need to start work on the front end in stages. What would be the first step? Upper and Lower ball joints? Thanks.
Id go lower ball joints, strut bushings and lower control arm bushings first. Then second upper ball joints and upper control arm bushings.
Have you had an inspection done?
Jeff is right start down low and work your way up. Only replace it if needed though.
No inspection, just wobble and tire scalloping. Just had a tire balance and same thing still happening. This very helpful. Thank you.
Just don't buy one of those all in one kits from Kanters/PST/Just Suspension.. cheaply made Chinese/Taiwanese parts that last as long as old fuel line and ethanol. Moog parts are still available, I've got a list of part numbers on the site to use.
If you're scalloping I'd look at shocks as well..
Where would I find that list 67440?
stonehengeheels Wrote:Where would I find that list 67440?
https://www.dodgecoronet.com/coronet/sho...sion-Parts
Mopars & Missiles Wrote:https://www.dodgecoronet.com/coronet/sho...sion-Parts
Thanks!! If your local auto parts store can't get them, believe it or not Amazon used to carry them.
  1967 RT value? andy@gesnerauto.com 0 7 7 hours ago
Last Post: andy@gesnerauto.com
  1967 Coronet Hemi Value strangleholdracn 7 1,574 04-02-22, 08:03 PM
  1967 Coronet rebuild thread. Piper 25 25,405 11-11-19, 02:20 PM
Last Post: Piper
  Happy Birthday 1967 Coronet. Hibbing_Coronet_500 9 5,225 04-16-17, 12:48 PM
  Guess Valvoline Racing Oil don't work........... markz 3 2,888 10-23-15, 07:16 PM
  1967 coronet front fiberglass bumper Stage III 2 3,462 07-01-15, 09:03 PM
  1967 R/T rear brake drum hemibro 12 8,046 11-26-14, 09:47 PM
  front end/ engine swap question...... bike_guy123 7 4,661 06-05-14, 10:55 PM
