How do I remove this piece of trim?
How do I remove this piece of trim? It's the one markrd 23 D/S. It's on a 68 coronet 440 2 door. 5821]
Take the inner panel off, with the window rolled up and you can get to the clips then
IIRC you can just squeeze them together. You might have to pull the headliner loose
and attack the rivet from the back also... Good Luck
you should be able to use a panel pop tool and get it behind the clip. If not listen to 68 500. Its been a while since I finished mine so my memory fails me.
Thank you for your answers. I'll give it a try.
  Last piece of the puzzle - 1966 Coronet convertible window trim CoVert66 3 1,048 09-23-22, 03:58 PM
  convertible rear seat trim bike_guy123 3 25,607 06-30-18, 07:17 PM
Last Post: bike_guy123
  55-56 horn button center piece restoration dodge55 4 22,716 02-11-18, 06:05 PM
Last Post: dodge55
  '68 Coronet 500 Exterior Trim Black JimKueneman 2 4,321 08-31-16, 10:49 AM
  1969 Coronet 500 4dr trim and molding needed ffhtrod 2 4,188 09-21-15, 04:01 PM
Last Post: ffhtrod
  Rear qtr window VERTICAL chrome trim seals..and Something I'm calling channel rubber.. TekHousE 8 5,847 09-03-15, 11:31 PM
  Stud welder to fill trim holes 67r/t4speeder 15 11,869 07-06-15, 02:52 PM
  1966 & 1967 Dodge & Plymouth B-Body Front Windshield Trim thebankerstoy 0 3,720 12-30-14, 12:20 AM
  Suggestions for Trim shop idougal 1 3,288 12-10-13, 09:31 AM
  1969 rear window trim? Warhawkfight34 1 3,195 10-31-13, 08:42 PM
Last Post: rip
