Header Starter Cleareance
FOUND IT!!..
Is it just me or is the Accel plug too short on the threads and electrode end? The insulator and plug end seem to be the same, but the electrode end doesn't look like it would extend into the combustion chamber at all. Not to mention the fact the hex part of the plug is too big..
Even with 1 7/8 tubes, I had to ding the hell out of #2 to get it to clear. And even then I needed some DEI plug protectors to keep it from burning up.
I thought the same..they list for 440s..also seen others had used them on eddy heads
TTI makes a 1 7/8 header for 440 with eddy heads.
Drag-Net Wrote:TTI makes a 1 7/8 header for 440 with eddy heads.
they are the ones I think I'll end up with, for now I'll break the motor in with these iron pretzels
Piper Wrote:today tech tip: remove the black tab!
You're killing me? I will post some pics of my old starter that came out of my race car (440 with the 5209 super comp headers) and it looks exactly like yours. Did not have to remove the black tab..............
  Plug wire to header clearance-how close is too close 67RTBlue 5 3,949 04-05-16, 09:55 PM
Last Post: Sedanman67
  Turn key right, no starter engagment DodgeT 4 4,124 12-10-14, 04:09 PM
  Header tube dia. BooBoo 3 4,012 09-06-13, 04:29 PM
  Starter Relay / Ignition issue Zaq 9 5,390 06-04-13, 05:33 PM
Last Post: 71_deputy
  Mini starter with shorty headers Zaq 3 4,504 01-14-13, 11:16 AM
Last Post: FRATZOG
