Turn key right, no starter engagment
I just replaced the ignition switch, no luck. Starter solenoid? I think my fuseable link is fine. Everything else works, I just can't get the starter to fire.
1969 Dodge Coronet R/T
440, 4 barrel, 727, Ramcharger
did you try the flat screwdriver in the starter relay trick? it would rule out some things.
65rbdodge Wrote:did you try the flat screwdriver in the starter relay trick? it would rule out some things.
Thanks for the reminder. I just tried that and she spun. Guess I will order a starter relay. Suggestions on the best place to get it?
It also could be the neutral safety switch. Try moving the shift lever back and forth in both park and neutral with the key turned all the way to start.
2x ⬆
  My turn for help 67440Dodge 10 1,546 10-01-22, 08:50 PM
  Turn Signal Wiring markz 5 5,795 10-12-16, 11:25 AM
Last Post: crlush
  Header Starter Cleareance Piper 15 8,724 08-20-14, 10:48 PM
  Starter Relay / Ignition issue Zaq 9 5,390 06-04-13, 05:33 PM
Last Post: 71_deputy
  Fender turn signal bulbs Coronet 14 8 5,667 05-21-13, 04:57 PM
Last Post: Coronet 14
  1967 Coronet front bumper turn indicators Hibbing_Coronet_500 10 7,762 05-06-13, 09:36 PM
  Mini starter with shorty headers Zaq 3 4,504 01-14-13, 11:16 AM
Last Post: FRATZOG
