New carb?
I will definitely try that next. I have to say a huge thanks to all of you! I am so glad I found this forum, you guys are awesome! I look forward to getting to know you all better and getting to share the journey of my Coronet with you all!
Tom66-500 Wrote:It had maybe a gallon or two that was about a few years old. I put some stabil in it along with about 5 gallons of fresh gas. Do you think that could be the cause?
That gas IS really too old, winter's not too bad on it, but summer heat is BAD! I would just dump it or mix it with some fresh in a driver.
When is the last time you checked the plugs? You might want to just check each for condition to see if there are any differences cylinder to cylinder.
WS27, I did a full tune up at the same time I rebuilt the carb. All gaps, points and plugs, are correct. I started a new post under modernize your Coronet talking about dropping either a new 5.7 or 6.1 Hemi in it and I decided that's the route I'm gonna go. I will probably still tinker with it and see if I can get it running decent enough to hit a few local shows this year but I will be tearing it down in the next few months to get it prepped for the new engine. Check out my other post because I'm having you all vote on which engine I will drop in it. I like both motors so I'm game for either.
  440 build questions. Intake,carb,torque converter? 67RTBlue 18 10,878 06-12-16, 11:24 PM
Last Post: BBishere2
  Carb spacer/adaptor Avenger 5 5,918 07-15-14, 02:25 AM
  Edelbrock 1405 carb tgranthamfd 13 10,575 04-27-14, 07:24 AM
Last Post: tgranthamfd
Last Post: rip
