Threads: 43
I can get a great deal on a holley 600 CFM 1850-s its reman but also comes with a lifetime warranty. What would be a good spacer/adaptor to use for it on the 318 poly cast intake..
-John
Threads: 43
Threads: 40
Truthfully unless you are going to race it, don't bother with anything other than a thin spacer to isolate the heat. That is my opinion..........
Threads: 43
07-14-14, 04:21 PM
(This post was last modified: 07-14-14, 04:26 PM by Avenger.)
I was just wondering if with the holley if the butterflies would clear the intake holes fine or not..thats mainly the reason i was asking about a spacer or if it even really needs one at all if it is going to clear anyways
Threads: 299
markz Wrote:Truthfully unless you are going to race it, don't bother with anything other than a thin spacer to isolate the heat. That is my opinion..........
X2
Threads: 40
Avenger Wrote:I was just wondering if with the holley if the butterflies would clear the intake holes fine or not..thats mainly the reason i was asking about a spacer or if it even really needs one at all if it is going to clear anyways
You should be fine.............
