Power disc brake kits
I found the parts listing for when I did mine about 10yrs ago. Using junkyard spindles/brackets/hold down hardware and buying everything else new (calipers, hoses, rotors, MC, adj prop valve, etc..) it came close to $500. Could have done it cheaper if I had cores, but the car I got it off of only had the spindles and brackets left.
Last Post: Mark's 69
Last Post: herklots
