Rear leaf springs. Gotta get rid of air shocks!
As for re-arching the springs, I took my MP springs to get them re-arched, and the company looked at them and basically said they'd do it, but they'd be sagging again real soon.
67440Dodge Wrote:As for re-arching the springs, I took my MP springs to get them re-arched, and the company looked at them and basically said they'd do it, but they'd be sagging again real soon.
Different quality steel than OEMs
My guy said same about most after market . And it depends if they are tapered .
If you want to shop a little bit closer to home, Standard Spring in Inver Grove Heights, Mn. can take of your needs too. Especially if you have to make a trip to St. Paul. Just more food for thought.....
Edit to my above post;
Standard Spring is in St Paul
Kremer Spring is in Inver Grove Heights. They both do a good job of rebuilding or re-arching.
I had air shocks on my RR, I got tired of the car looking "jacked up" in back, I let most of the air out and the springs just sagged, had to go down and order new springs, but that was back in the mid 70's.
Did you replace anything on the front suspension to go lower?
Last Post: revel68
  70 Coronet E-Brake Springs? blownNinjected 2 3,282 06-05-15, 07:07 PM
Last Post: blownNinjected
Last Post: Dionisio -C-
  Rear Sway bars on a WAGON??? rolling18 8 6,066 02-14-15, 02:15 PM
