Fuel take sending unit
I know this was asked in the old Coronet forum.
Do you have to drop the tank to change sending unit?
No, just make sure the gas level is lower that the hole! Just so you know, the new sending units won't necessarily be accurate. Sometimes it's better to repair the old if it still works.
Mine works. Full tank= 3/4
3/4 tank = 1/2
1/2 tank = 1/4 to empty depending. I don't like to run with a "full" tank because the rubber elbo is crusty and it will leak fuel if the fuel level is FULL.
I ordered a new one from classic due to be here next week.
You might be able to adjust the old one, also check to make sure the float is not partially full.
  Fuel tank vents Stargazer 11 8,084 08-04-16, 10:28 PM
Last Post: metaldad
  Fuel tank to fuel line rubber hose picture 67RTBlue 12 6,972 01-27-16, 02:25 PM
  Fuel filler leaking cnmsales 5 4,006 12-18-15, 06:01 PM
Last Post: Drag-Net
Last Post: Billb66
  Fuel pressure of a stock 318 tkarman 2 3,148 05-22-15, 03:26 PM
Last Post: tkarman
  fuel gage and temp light inop on 67 BooBoo 18 9,622 04-22-13, 12:16 PM
Last Post: BooBoo
