Threads: 6
Does anyone know what the clips the screws go into look like? Everything I've tried is not fat enough to go around the plastic on both sides.
If so, where can you buy them?
Threads: 79
I know what your talking about. If the screw is long enough just hold the J-nut inside while you tighten it. This can be done with the console cover off-(2 screws). The original clips barely stay on when installed properly anyways. They weren't wide or deep enough.
Threads: 6
Yes j-nut that's what I'm looking for. There was just a flat piece of tin with a hole drilled in it to hold them on. The j-nuts I've tried aren't long enough to reach the hole in the console or fat enough to fit around the plastic.
Threads: 79
Ya I know bad design. Try a very small j-nut like I said and just hold it up in the back until the screw grabs.
