07-16-14, 11:25 PM
65 Coronet 500, original 727, console shift, have Imperial shifter cable (I think), running stock shifter. I want to stay with the stock set up. I guess I'm old skool. After fixing (almost) the gazillion trans leaks, reinstalled the cable, followed the Ma Mopar service manual, adjusted cable at the trans, lined up the hole, turned the adaptor 4 ( I think) more holes and done. Shifted great for few weeks. Not sure if related but recently ran some wires under passenger side of console, installed fire ext. on side of console and problems began the next day. I have since removed extinguisher, removed wiring, problem persists. At first, wouldn't start in park, only neutral. Then wouldn't go into reverse after I adjusted it to start....great muscle car experience for my buddies who hadn't enjoyed an old car in many years as they loved pushing me out of parking spots. Also, noticed wouldn't manually shift 1 to 2 or 2 to D unless I bumped the shifter just past the intended gear - then back into the gear. Basically could only drive in D. Where's the fun in that ? Anyway, figured it must be the adjustment in console. Manual says there are 2 alignment marks to use when adjusting the shifter - can't see mine anywhere. No prob I figured. Loosed the small lock nut, adjust the big nut and should be done. So................
5 days of carrying my socket and open end wrench, adjusting a thousand times, I'm ready to throw wrenches. Adjust it one way, I got no start in park, adjust another way, it starts, has no reverse. After a few days of trying, gave up, backed adjustment all the way out and started from scratch. Guess what, same problems. I should also say that when it starts, both reverse and neutral are neutral and there is no reverse. I'm assuming the linkage and pivots are just too worn out but not really sure. Suggestions would be greatly appreciated unless you tell me to buy a chevy !
