67 b body console
Can a 1967 b body automatic console be converted to 4 speed?
Thanks for any information
yea I think i saw the console decks at year one
I know the top is available and the side is also.
But I wondered if it can be cut to match the 4 speed side panel?
Thanks Jim
They can be cut if needed.
Below are pictures of reproduction 1967-1970 B-Body automatic and 4 speed console bodies. I do know that the console mounting brackets, the left side console side moulding trim and the front shifter top finish plates are different between the 4 speed and automatic consoles and the left side console moulding trim mounting holes on the 4 speed and automatic console bodies are in different locations, so you'd have to deal with that, but maybe you could cover those holes with the console body carpeting?
I think that this conversion might be possible if you had all of the specialized 4 speed console parts on hand, but you might consider purchasing one of the reproduction 4 speed side covers if you don't already have one to see if it will match up to the automatic console body or not. The reproduction side covers run around $95.00 from various Mopar aftermarket parts suppliers.
4 speed console body.
[Image: BEApart131-4CONSOLE-1967-70consoleb.jpg]
Automatic console body.
[Image: BEApart131-ACONSOLE-1967-70consoleb.jpg]
4 speed console side cover.
[Image: 131-66CFB.jpg]
1966-1968 4 speed shifter top plate.
[Image: 131-8.jpg]
1966-1968 Automatic shifter top plate.
[Image: 131A-8.jpg]
Thank you that is exactly what I needed to know!!!
Jim
skeehorse Wrote:Richard
Jim
Hello again Jim,
I found a couple of nice pictures that show the difference between the 1966 through 1970 automatic and 4 speed floor console mounting brackets. Obviously the middle bracket for the automatic style consoles that the shifter mounts to won't work for the 4 speed set-up, so you will need to verify if the 4 speed mounting brackets with interchange with the automatic console body that you have, as well as checking to see if the 4 speed side cover will mate up to the automatic console body like we've already discussed.
Please double check everything that you feel might be an issue on this conversion BEFORE you do any modifications on your console body, because having to purchase a replacement console body won't be inexpensive and I'd really hate to see you have to do that. I wish that I could tell you if this conversion will work for sure or not, but I can't because I've never done it myself, or seen anybody else do it, so you're travelling into unknown waters my friend.
Here are the reproduction 4 speed console mounting brackets. (available on Ebay if you need them)
[Image: %24%28KGrHqNHJBEE7%29%29HtcwUBO9OtOGs-g%7E%7E60_12.JPG]
And the console mounting brackets for the automatics. (also available on Ebay)
[Image: %24%28KGrHqVHJDME7zj53N2GBO9Oq1JDiw%7E%7E60_12.JPG]
  1969 console style ? 67r/t4speeder 4 295 05-20-23, 02:02 PM
  Recalibrate a factory console tach? 67RTBlue 1 3,217 03-19-17, 05:45 PM
  Center console courtesy lamp retaining clips Red 67 3 4,291 11-30-16, 12:21 PM
  Body Work for vintage cars - Atlanta dodge55 0 2,394 03-24-16, 09:36 PM
Last Post: dodge55
Last Post: tgranthamfd
  B body big block oil pan replace Mark's 69 9 6,352 06-17-15, 01:35 PM
  OMG I suck at fixing cars !!!!!!!!!!!!!!!!!!!!!!65 console auto shifter problem use2teech 6 6,025 07-22-14, 04:32 AM
Last Post: mrconvertible
  how to you convert a column shift car to a console car??? joshua 7 5,760 03-17-13, 03:18 PM
Last Post: joshua
