Progress on my 67 Coronet R/T
#41
This finally gets this post current! Here is the section I cut for a patch from the AMD panel.
8567]
If it ain't broke, fix it 'til it is...
Welded the patch in tonight. Still needs a little touch up work, but almost done.
8572]8573]8574]
Thanks for showing the progress looks like it is turning out great!
Made one more small patch and test fit the trunk floor. Looks like it will fit perfect.
8580]8581]8582]
skeehorse Wrote:Thanks for showing the progress looks like it is turning out great!
Thanks! Lots of time and money! Also, a lot of sweat here lately. Every day has been over 90 degrees for a few weeks.
You're about 200 miles from me, if I ever need "some" welding, I'll give you a buzz, looks great!
Looking good! And your doing it right too!
Racer Brown Wrote:You're about 200 miles from me, if I ever need "some" welding, I'll give you a buzz, looks great!
I've been using the same cheap Century 110 mig welder for probably 20 years. It was my dads so I used it to learn. When I moved out he gave it to me, along with a bunch of other tools. I'm not that great of a welder, but I can get it done. Not always pretty. Luckily, you grind body welds!
You do very nice work. Curious how far are you from me? Cincinnati.
You would be sick if I told you what I sold a great original pan, floor pan, inner and outer wheel wells and full quarters for. Did it to just get it out of my garage. Sold it about 3 years ago.
markz Wrote:You do very nice work. Curious how far are you from me? Cincinnati.
I'm about 2 hours from Cincinnati. Good parts for these cars are hard to find! I'm used to Cudas and Challengers. You can buy every piece on them.
  Last piece of the puzzle - 1966 Coronet convertible window trim CoVert66 3 1,045 09-23-22, 03:58 PM
  1967 Coronet needs hood alignment 440net 1 1,484 10-15-21, 07:38 AM
Last Post: dodge55
Last Post: don99pablo
Last Post: David Lee
  '68 Coronet Taillights JimKueneman 0 3,352 10-01-16, 05:20 PM
Last Post: JimKueneman
