Progress on my 67 Coronet R/T
I've been restoring this car for several months now so I'll start from the beginning and try to get up to date with it. Here it is as I bought it.
8451]8452]8453]8454]8455]8456]8457]8458]8459]8460]8461]8462]
I wondered why the back seat was so heavy when I took it out. Then it started moving. This guy was living in there!
8463]
Removed the windshield to find shiny factory paint
8464]
Rear floor is in pretty good shape. Just a few pinholes. Finally got it up to the garage to start the real work.
8465]8466]
Wire wheeling and rust encapsulator.
8467]
Getting everything down to bare metal and shooting an epoxy primer.
8468]
No rust in the rockers. 8469]8470]
So did you see if the build sheet was in his stomach Smile
Drivers door is original and not too bad, but the lower front corner needed some work. Cut out the bad part of the skin and the flange where it wraps around was pretty much gone. Made a new flange and a patch for the skin. Came out pretty good.
8471]8472]8473]8474]8475]8476]8477]8478]
JimKueneman Wrote:So did you see if the build sheet was in his stomach Smile
He was pretty big. May have ended up there myself!
  Last piece of the puzzle - 1966 Coronet convertible window trim CoVert66 3 1,048 09-23-22, 03:58 PM
  1967 Coronet needs hood alignment 440net 1 1,485 10-15-21, 07:38 AM
Last Post: dodge55
  1966 Coronet 500 rear leaf springs richardmay2 3 13,427 07-18-17, 01:30 PM
Last Post: don99pablo
Last Post: David Lee
  '68 Coronet Taillights JimKueneman 0 3,352 10-01-16, 05:20 PM
Last Post: JimKueneman
