67 Coronet grey/silver strips top and bottom of grill
I pulled out the original grill from my R/T from storage. I remembered seeing that the grill was black with silver or grey stripes horizontally on each edge of the top and bottom on the vertical bars. The one mounted on the car is all silver color. I've seen others that were either black, and some were silver. Anyone know which is correct. I'll post a picture after work, I repainted the black part but it definitely has a strip on the top and bottom. Thanks for your help.
this is member 67RTBLUE beautiful grill and I believe this is correct 8851]
I've seen that one but also saw some pics of the recent show at Carlyle, and a couple of cars had the black grill. I have seen others on the Web that way also. THIS is the way I got it with the car. I just redid the black part to see if I would do the one one the car the same.
This is what I'm talking about. I've seen a few like this and some natural finish.
Not factory but if YOU like it go for it! Why be the same as everyone else?
I put the 500 grill center on that I have and the chrome seems to line up with the grey line although there are no cross bars. Do they bolt on or what?
RT K_line Wrote:This is what I'm talking about. I've seen a few like this and some natural finish.
That is the result of combining a RT center grille section and headlight doors with a Coronet 500 grille without stripping the black paint off the Coronet 500 grille.
Jim 68cuda Wrote:That is the result of combining a RT center grille section and headlight doors with a Coronet 500 grille without stripping the black paint off the Coronet 500 grille.
Yep
Thanks for the information. At least I know what I have.
440 grill (polished with center medallion)
9573]
500 Grill (black with the center stripe and medallion) (note the headlights on the 500 are different as well)
9574]
R/T grill (polished with medallion delete)
9575]
Hope this helps.
  Last piece of the puzzle - 1966 Coronet convertible window trim CoVert66 3 1,045 09-23-22, 03:58 PM
  1967 Coronet needs hood alignment 440net 1 1,484 10-15-21, 07:38 AM
  Progress on my 67 Coronet R/T Callingdrlove01 120 52,112 02-11-19, 04:26 AM
Last Post: Callingdrlove01
Last Post: dodge55
Last Post: David Lee
  '68 Coronet Taillights JimKueneman 0 3,352 10-01-16, 05:20 PM
Last Post: JimKueneman
