'66 Coronet outer wheelhouse...end caps...cross member...
Having trouble finding outer wheelhouses for 66-67. Should I order the 68-70 and make them work, or are there any other ideas or resources?
Also need to find end caps for my trunk floor extensions.
And one more - rear cross member where the bumper reinforcements are located. Found some on Auto Body Specialty, but there is just a diagram, no picture. Is that what I need?
68/9 are completely different beasts when it comes to outer wheelhouses. Your best bet is to try and find a donor car that may have a solid piece, or try to fabricate the sections that are missing. You can also contact Auto Rust Technicians in Rhode Island. They might be able to fabricate a set.
Might want to check Sherman & Associates parts. they used to carry those pieces, but not sure anymore.
if you are talking the panel that goes across from each side of the car in the back behind the bumper, yes that is it.
I use Desert Vally Auto Parts for moments like these. They always send good quality used parts pulled from thousands of cars, huge selection. http://www.DVAP.com
[/URL]
Thanks guys for your input.
  Last piece of the puzzle - 1966 Coronet convertible window trim CoVert66 3 1,048 09-23-22, 03:58 PM
  1967 Coronet needs hood alignment 440net 1 1,485 10-15-21, 07:38 AM
  Progress on my 67 Coronet R/T Callingdrlove01 120 52,113 02-11-19, 04:26 AM
Last Post: Callingdrlove01
Last Post: dodge55
  1966 Coronet 500 rear leaf springs richardmay2 3 13,428 07-18-17, 01:30 PM
Last Post: don99pablo
Last Post: David Lee
