engine oil for 383 HP
I was wondering what folks use for their preferred engine oil for the 383 High Performance engine, but not necessarily with the HP cam. I am thinking of the 1969 4 barrel-383 engine (not the magnum).
Maybe a 20/50, or even a diesel oil? Advice on zinc additives?
Thanks for what you may be able to offer.
My buddy uses Royal Purple synthetic 20W50 engine oil in his 383 Coronet.
VR-1 Valvoline works great and it has zinc
Available in most all parts stores
Anything with Zinc in it.
any 10w30 with any zinc additive. that's what I use in ALL of my motors.
Same here, 10W30 in my every day engines. It all depends on intended use in whatever season or activity you put your engine through. The secret is to keep the oil clean and stick to a scheduled oil/filter change religiously. I keep records and reminders on my desk and in my truck in plain view. Even my generator and power washer get frequent oil changes as does the transmission/transfer case and rear end in any road vehicle I use including the ATV and boat engine. Good clean oil with lots of volume at the oil pump help ensure a long lasting engine on a Mopar. Zinc additive of course is paramount.
I have been useing Rotella 15 - 40 for several years now.
last 3 or 4 years I have been adding a pint of lucas zinc additive just to be safe.
I think the 15 - 40 holds up good to heat , I change it every 3,000 so it gets changed 2 times each summer, engine stays clean inside , no sludge ect.
Thanks 67rt 4 speeder, I bought the VRI after reading the specs and checking the price.
  Recommend engine swap shop fitzyb5 2 2,937 10-13-17, 11:25 PM
Last Post: Dingusboy
  Engine problems all opinions welcome. Warhawkfight34 20 8,227 08-22-17, 08:23 AM
Last Post: Warhawkfight34
  Looking for 67 R/T engine bay pictures jworz71 12 8,387 12-19-16, 11:13 PM
Last Post: jworz71
  Engine and transmission questions odot365 14 9,158 08-21-16, 09:21 PM
  Almost done detailing the engine bay. Heres some updated pics. Warhawkfight34 16 10,511 01-26-15, 11:37 AM
  1960 383 cross ram engine alwayslooking 0 2,573 12-24-14, 11:42 PM
Last Post: alwayslooking
  Help verifying H code engine 1968Coronet500 3 3,395 09-28-14, 10:49 PM
  Engine is FINALLY INSTALLED Warhawkfight34 10 6,213 06-12-14, 08:29 PM
Last Post: dadstoy65
  front end/ engine swap question...... bike_guy123 7 4,661 06-05-14, 10:55 PM
